Giriş
This is a guide on replacing the Headlights on a 97-01 model Honda Prelude. This guide includes disassembly for the front end of the car as well as installing HID bulbs over stock replacement parts.
Neye ihtiyacın var
Make sure that your car is parked on a level surface with the emergency brake on. A common workplace for anyone without a garage is a driveway or carport.
Locate the positive and negative leads on the battery and remove them with a 10mm socket.
There are 7 body screws to be removed that attach the front bumper to the frame of the car. The first 5 screws are all on the same eye level as the underskirt of the car whereas screws 6 & 7 are above the passenger and driver side tires.
There are 2 screws which attach the grille and the front bumper to the frame which are located directly next to either headlight. Once the grille is removed, there are five plastic tabs which must also be removed before taking off the bumper.
Now as you remove the front bumper, be sure to only pull it off far enough to reach down and unplug the wires to the passenger and driver side blinkers and running lights. Alternatively to freeing the wire, the bulb and wire harness may both be freed by twisting counterclockwise. Once everything is unplugged, pull gently until the bumper is free.
There is a wire harness for the high beam and low beam which may be freed by twisting counterclockwise. This should be done for passenger and driver side before attempting to remove the screws that secure the headlights.
There are 3 screws securing each headlight. The top screw is the easiest to get to and can be removed in plain sight before even taking the front bumper off. The screws on the sides, however, are seen only after the bumper is removed and are still difficult to get to.
When removing the headlight, take care to avoid touching any bulbs with your hands or wear a latex glove. Furthermore, do not force the assembly to come out. If the assembly does not come free with a gentle pull then something is likely still attached.
If HIDs are installed, then the factory wire harness no longer clips in. Now, you will need to place the positive and negative leads from the HID into the wire harness. Following, secure the connection with electrical tape. Furthermore, you may secure the ballasts for the HIDs to the frame of your car with zip ties.
Enjoy your new Headlights!
3 farklı kişi bu kılavuzu tamamladı.
