Ana içeriğe geç
Honda S2000 VTEC Solenoid Upper Replacement
Neye ihtiyacın var
  1. Honda S2000 VTEC Solenoid Upper Replacement, VTEC Solenoid Upper: adım 1, 2 resimden 1. Honda S2000 VTEC Solenoid Upper Replacement, VTEC Solenoid Upper: adım 1, 2 resimden 2.
    • Locate Vtec Solenoid on front left of engine.
  2. Honda S2000 VTEC Solenoid Upper Replacement: adım 2, 3 resimden 1. Honda S2000 VTEC Solenoid Upper Replacement: adım 2, 3 resimden 2. Honda S2000 VTEC Solenoid Upper Replacement: adım 2, 3 resimden 3.
    • Locate and remove 3 bolts.
    • Do not drop cable that is attached by a bolt.
  3. Honda S2000 VTEC Solenoid Upper Replacement: adım 3, 3 resimden 1. Honda S2000 VTEC Solenoid Upper Replacement: adım 3, 3 resimden 2. Honda S2000 VTEC Solenoid Upper Replacement: adım 3, 3 resimden 3.
    • Pull the plug upwards off of metal cable holder, and then disconnect the two cables.
  4. Honda S2000 VTEC Solenoid Upper Replacement: adım 4, 3 resimden 1. Honda S2000 VTEC Solenoid Upper Replacement: adım 4, 3 resimden 2. Honda S2000 VTEC Solenoid Upper Replacement: adım 4, 3 resimden 3.
    • Remove the metal cable holder and set it to the side.
    • Pull off the upper Vtec Solenoid.
  5. Honda S2000 VTEC Solenoid Upper Replacement: adım 5, 3 resimden 1. Honda S2000 VTEC Solenoid Upper Replacement: adım 5, 3 resimden 2. Honda S2000 VTEC Solenoid Upper Replacement: adım 5, 3 resimden 3.
    • Grab a new replacement upper Solenoid.
    • Place the gasket (new or used if still good) into its slot.
    • Spread a small amount of oil all along the gasket.
  6. Honda S2000 VTEC Solenoid Upper Replacement: adım 6, 2 resimden 1. Honda S2000 VTEC Solenoid Upper Replacement: adım 6, 2 resimden 2.
    • Insert wisdom here.
  7. Honda S2000 VTEC Solenoid Upper Replacement: adım 7, 3 resimden 1. Honda S2000 VTEC Solenoid Upper Replacement: adım 7, 3 resimden 2. Honda S2000 VTEC Solenoid Upper Replacement: adım 7, 3 resimden 3.
    • Grab metal cable holder and place one of the bolts into it.
    • Hand tighten all three bolts.
    • Ensure the metal cable holder is straight.
  8. Honda S2000 VTEC Solenoid Upper Replacement: adım 8, 3 resimden 1. Honda S2000 VTEC Solenoid Upper Replacement: adım 8, 3 resimden 2. Honda S2000 VTEC Solenoid Upper Replacement: adım 8, 3 resimden 3.
    • Tighten all 3 bolts with a ratchet.
    • Plug the cable back in, and attach it to the metal holder.
  9. Honda S2000 VTEC Solenoid Upper Replacement: adım 9, 2 resimden 1. Honda S2000 VTEC Solenoid Upper Replacement: adım 9, 2 resimden 2.
    • Wipe down the edges where the two parts meet to pick up any oil that may have spilled.
    • Keep a eye on solenoid for any oil leaking after cleaning.
Sonuç
You now have a proper working Solenoid, Just make sure to keep an eye on the solenoid in case of any oil leaks
Angeljauregui
169 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 148
Her zaman: 449
