Ana içeriğe geç
Honda civic 2016 Keyless Remote Battery Replacement
Neye ihtiyacın var
  1. Honda civic 2016 Keyless Remote Battery Replacement, Let's get started: adım 1, 2 resimden 1. Honda civic 2016 Keyless Remote Battery Replacement, Let's get started: adım 1, 2 resimden 2.
    • Make sure to have replacement battery ready. You will need 1 pc of CR 2032 Lithium battery.
    • Remove the metal key by sliding the switch on the back of the remote and pulling the key out.
  2. Honda civic 2016 Keyless Remote Battery Replacement, Cracking it open: adım 2, 3 resimden 1. Honda civic 2016 Keyless Remote Battery Replacement, Cracking it open: adım 2, 3 resimden 2. Honda civic 2016 Keyless Remote Battery Replacement, Cracking it open: adım 2, 3 resimden 3.
    • After removing the key, you will see 2 plastic bars. This is a place where you can split the remote open.
    • The manufacturer recommeded using a coin but any hard tool or even the key itself will work as well.
    • The manufacturer recommended using a cloth covering your coin/ tool to prevent it from denting the plastic bars.
  3. Honda civic 2016 Keyless Remote Battery Replacement, Removing the battery: adım 3, 3 resimden 1. Honda civic 2016 Keyless Remote Battery Replacement, Removing the battery: adım 3, 3 resimden 2. Honda civic 2016 Keyless Remote Battery Replacement, Removing the battery: adım 3, 3 resimden 3.
    • Now you can gently pry it open
    • Removing the old battery from the left side.
    • Remember that the + side of the battery is facing up.
  4. Honda civic 2016 Keyless Remote Battery Replacement, Inserting a new battery: adım 4, 2 resimden 1. Honda civic 2016 Keyless Remote Battery Replacement, Inserting a new battery: adım 4, 2 resimden 2.
    • Inserting a new CR 2032 battery from the right side first and then press the battery down. It should make a good 'click' sound
    • Again, make sure the + side of the battery is facing upward.
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Anan Venasakulchai
861 İtibar
2 adet Kılavuz yazıldı
Ekip
Finn Store Finn Store üyesi
Business
1 Üye
7 adet Kılavuz yazıldı
Bir Yorum
Super Anleitung mit sehr guten Fotos - vielen Dank!
Philipp Glück - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 25
Son 7 gün: 175
Son 30 gün: 571
Her zaman: 56,147
