Ana içeriğe geç
Honda civic 2019 Trunk Strut Replacement
Neye ihtiyacın var
  1. Honda civic 2019 Trunk Strut Replacement, Trunk Strut: adım 1, 1 resimden 1.
    • Open the trunk and use an object like a pole or a broomstick to securely prop it open. You may prefer to have another person hold the trunk open while making the repair. Hazard: If not properly supported, the trunk may fall during the repair causing potential injury.
  2. Honda civic 2019 Trunk Strut Replacement: adım 2, 1 resimden 1.
    • Locate the trunk strut on the far-left side of the trunk. Wedge a flat-head screwdriver below the small ring at the top of the strut. Use the screwdriver as a lever to pop out this ring, loosening the connection between the strut and the car.
  3. Honda civic 2019 Trunk Strut Replacement: adım 3, 1 resimden 1.
    • Pull the top of the strut horizontally until it is removed from the ball joint.
  4. Honda civic 2019 Trunk Strut Replacement: adım 4, 1 resimden 1.
    • Locate the other ring at the bottom of this same strut. Use a flat-head screwdriver to again pry up the ring.
  5. Honda civic 2019 Trunk Strut Replacement: adım 5, 1 resimden 1.
    • Pull the bottom of the strut horizontally until it is removed from the ball joint.
  6. Honda civic 2019 Trunk Strut Replacement: adım 6, 1 resimden 1.
    • Now that the left trunk strut is fully detached from the car body, install the new trunk strut by pushing the sockets of the strut into the ball joints where the old strut was removed.
  7. Honda civic 2019 Trunk Strut Replacement: adım 7, 2 resimden 1. Honda civic 2019 Trunk Strut Replacement: adım 7, 2 resimden 2.
    • Repeat Steps 2-6 for the right trunk strut. Make sure that the left trunk strut has been fully replaced before detaching the right trunk strut.
Sonuç
Peyton Batte
145 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 124
Her zaman: 500
