Ana içeriğe geç
Honeytone N-10 Mini Amp Speaker Replacement
Neye ihtiyacın var
  1. Honeytone N-10 Mini Amp Speaker Replacement, Speaker: adım 1, 2 resimden 1. Honeytone N-10 Mini Amp Speaker Replacement, Speaker: adım 1, 2 resimden 2.
    • Flip your amp over to begin removing the plastic cover.
  2. Honeytone N-10 Mini Amp Speaker Replacement: adım 2, 2 resimden 1. Honeytone N-10 Mini Amp Speaker Replacement: adım 2, 2 resimden 2.
    • Remove the battery cover and take the battery out.
    • Unless you want a quick pick-me-up, in which case feel free to leave it in and get shocked.
  3. Honeytone N-10 Mini Amp Speaker Replacement: adım 3, 2 resimden 1. Honeytone N-10 Mini Amp Speaker Replacement: adım 3, 2 resimden 2.
    • Unscrew the four corner screws using a phillips #0 screw driver to remove the back cover.
    • While the screws are recessed deep into the cover and difficult to see, 2-4 turns will easily release them.
  4. Honeytone N-10 Mini Amp Speaker Replacement: adım 4, 3 resimden 1. Honeytone N-10 Mini Amp Speaker Replacement: adım 4, 3 resimden 2. Honeytone N-10 Mini Amp Speaker Replacement: adım 4, 3 resimden 3.
    • Remove the back cover by carefully pushing the battery connector through the hole in the cover.
  5. Honeytone N-10 Mini Amp Speaker Replacement: adım 5, 3 resimden 1. Honeytone N-10 Mini Amp Speaker Replacement: adım 5, 3 resimden 2. Honeytone N-10 Mini Amp Speaker Replacement: adım 5, 3 resimden 3.
    • With the phillips #0 screwdriver, unscrew the two white plastic clips that hold the speaker in place.
  6. Honeytone N-10 Mini Amp Speaker Replacement: adım 6, 2 resimden 1. Honeytone N-10 Mini Amp Speaker Replacement: adım 6, 2 resimden 2.
    • Use flush wire cutters to remove black and red wires from the old speaker.
    • Note: The black wire has already been removed in this example image.
  7. Honeytone N-10 Mini Amp Speaker Replacement: adım 7, 3 resimden 1. Honeytone N-10 Mini Amp Speaker Replacement: adım 7, 3 resimden 2. Honeytone N-10 Mini Amp Speaker Replacement: adım 7, 3 resimden 3.
    • Connect the new speaker by soldering the black and red wires to the negative and positive connections respectively
  8. Honeytone N-10 Mini Amp Speaker Replacement: adım 8, 1 resimden 1.
    • Connect the battery and turn the power on to test proper connection of the new speaker.
    • Some static is fine, this is the natural sound of the amp.
    • Careful not to touch any of the metal components inside while temporarily testing the connection.
  9. Honeytone N-10 Mini Amp Speaker Replacement: adım 9, 1 resimden 1.
    • Reverse steps 1-5 to complete repair.
    • Connect the amp to your favorite instrument and test out the new sound!
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
Corey Brown
8.682 İtibar
11 adet Kılavuz yazıldı
Bir Yorum
Cool. If mine doesn’t work, is it likely to be the speaker? Thanks.
hupaand - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 3,489
