Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Flip your amp over to begin removing the plastic cover.
Unscrew the four corner screws using a phillips #0 screw driver to remove the back cover.
Remove the back cover by carefully pushing the battery connector through the hole in the cover.
With the phillips #0 screwdriver, unscrew the two white plastic clips that hold the speaker in place.
Use flush wire cutters to remove black and red wires from the old speaker.
Connect the new speaker by soldering the black and red wires to the negative and positive connections respectively
Connect the battery and turn the power on to test proper connection of the new speaker.
Connect the amp to your favorite instrument and test out the new sound!
3 farklı kişi bu kılavuzu tamamladı.
