Giriş
This guide is necessary to complete before many of our other replacement guides, but it can also stand alone as a replacement guide for the control panel. This is a really simple guide and should only take you a few minutes!
Neye ihtiyacın var
Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
Remove the two 3mm screws found just below the top of the device using the Phillips #0 Screwdriver.
Neredeyse bitti!
Sonuç
