Giriş
After removing the outer casing, replacing the fan blades is quick and easy! You would want to use this guide to replace the broken part or clean dirty blades.
Neye ihtiyacın var
Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
Remove the hex nut from the fan motor with a 10mm hexagonal ratcheting socket wrench.
Neredeyse bitti!
Sonuç
