Ana içeriğe geç
Honeywell HY-204 Rotation Button Replacement
Neye ihtiyacın var
  1. Honeywell HY-204 Rotation Button Replacement, Case: adım 1, 2 resimden 1. Honeywell HY-204 Rotation Button Replacement, Case: adım 1, 2 resimden 2.
    • Before you begin, be sure to unplug the fan.
    • Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
  2. Honeywell HY-204 Rotation Button Replacement: adım 2, 2 resimden 1. Honeywell HY-204 Rotation Button Replacement: adım 2, 2 resimden 2.
    • Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
  3. Honeywell HY-204 Rotation Button Replacement, Control Panel: adım 3, 2 resimden 1. Honeywell HY-204 Rotation Button Replacement, Control Panel: adım 3, 2 resimden 2.
    • Remove the two 3mm screws found just below the top of the device using the Phillips #0 Screwdriver.
  4. Honeywell HY-204 Rotation Button Replacement: adım 4, 1 resimden 1.
    • Pry off the control panel by forcefully lifting the tab located inside the front of the fan with the plastic opening tool.
  5. Honeywell HY-204 Rotation Button Replacement, Rotation Button: adım 5, 2 resimden 1. Honeywell HY-204 Rotation Button Replacement, Rotation Button: adım 5, 2 resimden 2.
    • Remove the two 10mm Phillips #0 screws that are located next to the rotation button.
  6. Honeywell HY-204 Rotation Button Replacement: adım 6, 1 resimden 1.
    • Peel back the heat shrink tubing on both wires connecting to the button.
  7. Honeywell HY-204 Rotation Button Replacement: adım 7, 1 resimden 1.
    • Caution The soldering iron is very hot, be careful to avoid burns.
    • Desolder the two wires connected to the button and remove the button.
Sonuç
Nolan Ernotte
384 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-40, Amido Fall 2014 Cal Poly, Team 10-40, Amido Fall 2014 üyesi
CPSU-AMIDO-F14S10G40
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 986
