Ana içeriğe geç
Honeywell HY-204 Rotation Motor Replacement
Neye ihtiyacın var
  1. Honeywell HY-204 Rotation Motor Replacement, Rotation Motor: adım 1, 1 resimden 1.
    • Before you begin, be sure to unplug the fan.
    • Lay fan on the ground and use your fingers peel the three feet off the bottom of the fan.
  2. Honeywell HY-204 Rotation Motor Replacement: adım 2, 1 resimden 1.
    • Remove the three 12mm screws using the Phillips #0 Screwdriver.
  3. Honeywell HY-204 Rotation Motor Replacement: adım 3, 2 resimden 1. Honeywell HY-204 Rotation Motor Replacement: adım 3, 2 resimden 2.
    • Remove the two 10mm screws using the Phillips #0 Screwdriver.
  4. Honeywell HY-204 Rotation Motor Replacement: adım 4, 1 resimden 1.
    • Move the rotation motor left and right to reveal the screw connecting it to the fan.
    • Remove the 18mm screw from the side of the motor using the Phillips #0 Screwdriver.
  5. Honeywell HY-204 Rotation Motor Replacement: adım 5, 1 resimden 1.
    • Using the wire cutters, severe the wires connecting the rotation motor to the fan.
    • To put back together you will need to resolder or use wire connectors to reattach motor.
Sonuç
Armando Jacob Espinoza
500 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-40, Amido Fall 2014 Cal Poly, Team 10-40, Amido Fall 2014 üyesi
CPSU-AMIDO-F14S10G40
3 Üyeler
7 adet Kılavuz yazıldı
2 Yorum
It seems that these instructions are on “How to eeplacr the oscillation motor". But they neglect the requirement to have a replacement motor or how/where to get the replacement motor. Otherwise the steps seem clear.
Alan A. Kopta - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 10
Her zaman: 2,646
