Ana içeriğe geç
Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement
Neye ihtiyacın var
  1. Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement, Electrochemical Sensors: adım 1, 1 resimden 1.
    • Confirm which sensor you are intending to replace. Make note of it.
    • Nitrile gloves should be worn for the entire procedure.
    FixBot'a Sor
    Yorum Ekle
  2. Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement: adım 2, 2 resimden 1. Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement: adım 2, 2 resimden 2.
    • Place the monitor face down on a clean surface.
    • Use the Phillips #0 screwdriver to remove the single 3 mm Phillips screw on the belt clip.
    FixBot'a Sor
    Yorum Ekle
  3. Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement: adım 3, 1 resimden 1.
    • Starting at the bottom of the case, pull the outer case away from the main body of the monitor.
    • Continue pulling out and away until the entire outer case has been removed.
    FixBot'a Sor
    Yorum Ekle
  4. Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement: adım 4, 1 resimden 1.
    • With the Phillips #0 screwdriver, remove all four 3 mm screws from the rear pump/sensor cover.
    FixBot'a Sor
    Yorum Ekle
  5. Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement: adım 5, 1 resimden 1.
    • Remove the outer pump/sensor housing cover and set it aside.
    FixBot'a Sor
    Yorum Ekle
  6. Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement: adım 6, 1 resimden 1.
    • Carefully grip and twist the outer edge of the sensor to remove the sensor from its insertion point.
    • Be careful not to twist too aggressively as this could damage the sensor attachment point in the monitor.
    FixBot'a Sor
    Yorum Ekle
  7. Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement: adım 7, 3 resimden 1. Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement: adım 7, 3 resimden 2. Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement: adım 7, 3 resimden 3.
    • Grip the replacement sensor on the outer edge.
    • Insert the new sensor in a straight downward orientation.
    • Be careful to line up the prongs with their insertion/attachment point in the monitor.
    FixBot'a Sor
    Yorum Ekle
  8. Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement: adım 8, 1 resimden 1.
    • Reassemble the unit in reverse order.
    • After reassembly, power the unit on to ensure that the monitor recognizes the new sensor.
    • Calibrate the sensor per the manufacturer's instructions.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 26
Son 30 gün: 111
Her zaman: 3,235
