Giriş
If your Honeywell Turboforce Air Circulator is not working when you turn the device on, you may have a dead motor which needs replacing. Our guide will help show you how to properly remove the dead motor.
Neye ihtiyacın var
Using a Phillips #1 screwdriver, remove the six 15mm screws on the outer ring of the back of the fan holding the frame together.
11 farklı kişi bu kılavuzu tamamladı.
5 Yorum
What is the motor parts details to procure elsewhere?
Hi informative guide but first how do we get the new motor how do you remove the blade nut to remove the blade from the old motor shaft
Given the difficulty of finding a replacement motor with three speeds and the correct mounting configuration, it makes more sense to buy a new model of this fan. Much faster, too.
Sprockets John
Top notch how to document! Commentary and photos are excellent. Good job! And thank you very much
Where are y’all finding the motor? Please advise… this looks doable! Thank you for your assistance. Michelle
