Ana içeriğe geç
Hoover Lander (LA71_LA30011) Motor filter Replacement
Neye ihtiyacın var
  1. Hoover Lander (LA71_LA30011) Motor filter Replacement, The Hoover: adım 1, 2 resimden 1. Hoover Lander (LA71_LA30011) Motor filter Replacement, The Hoover: adım 1, 2 resimden 2.
    • 700 w cyclonic hoover
  2. Hoover Lander (LA71_LA30011) Motor filter Replacement, The filter (broken one): adım 2, 3 resimden 1. Hoover Lander (LA71_LA30011) Motor filter Replacement, The filter (broken one): adım 2, 3 resimden 2. Hoover Lander (LA71_LA30011) Motor filter Replacement, The filter (broken one): adım 2, 3 resimden 3.
    • The active carbon filter is totally blocked. Air cannot flow !!!
  3. Hoover Lander (LA71_LA30011) Motor filter Replacement, Remove the carbon filter: adım 3, 3 resimden 1. Hoover Lander (LA71_LA30011) Motor filter Replacement, Remove the carbon filter: adım 3, 3 resimden 2. Hoover Lander (LA71_LA30011) Motor filter Replacement, Remove the carbon filter: adım 3, 3 resimden 3.
    • Using a screwdriver and a cutter is almost simple to remove the filter.
  4. Hoover Lander (LA71_LA30011) Motor filter Replacement, Goods to replace the filter: adım 4, 3 resimden 1. Hoover Lander (LA71_LA30011) Motor filter Replacement, Goods to replace the filter: adım 4, 3 resimden 2. Hoover Lander (LA71_LA30011) Motor filter Replacement, Goods to replace the filter: adım 4, 3 resimden 3.
    • Metal grid
    • Foam
    • Gauze
  5. Hoover Lander (LA71_LA30011) Motor filter Replacement, Building the new filter: adım 5, 2 resimden 1. Hoover Lander (LA71_LA30011) Motor filter Replacement, Building the new filter: adım 5, 2 resimden 2.
    • Cut the metal grid and place it.
    • Place the gauze (just a couple of sheets) over the grid.
    • Cut and place the foam on top of the gauze.
  6. Hoover Lander (LA71_LA30011) Motor filter Replacement, The - new - Filter: adım 6, 2 resimden 1. Hoover Lander (LA71_LA30011) Motor filter Replacement, The - new - Filter: adım 6, 2 resimden 2.
    • Insert wisdom here.
  7. Hoover Lander (LA71_LA30011) Motor filter Replacement, Reassemble: adım 7, 3 resimden 1. Hoover Lander (LA71_LA30011) Motor filter Replacement, Reassemble: adım 7, 3 resimden 2. Hoover Lander (LA71_LA30011) Motor filter Replacement, Reassemble: adım 7, 3 resimden 3.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Carlo Romagnoli
310 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 549
