Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Detach the rolling assembly from the body by pushing the button found at the base.
Remove the seven 7.5mm Phillips #1 screws from the brush retainer.
Remove the brush and retainer from the rolling assembly.
Remove the eight 4mm Phillips #1 screws from the bottom panel.
3 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Thank you for the photos! They’ve been helpful as I’m putting my Linx back together and can’t quite remember how the wires go back in the nozzle assembly. When putting the top plate back on, it’s a very tight fit where the top will be pushed up if maligned.
In the elbow part- It looks like the positive lead is on the left in your photo, but it would be helpful if you would add that specification to your step.
Great Job!
