Ana içeriğe geç
Hoover LiNX Power Button Replacement
Neye ihtiyacın var
  1. Hoover LiNX Power Button Replacement, Hoover LiNX Handle Teardown: adım 1, 1 resimden 1.
    • Remove the single 15mm Phillips #1 screw from the handle.
  2. Hoover LiNX Power Button Replacement: adım 2, 1 resimden 1.
    • Remove the handle by pulling it up.
  3. Hoover LiNX Power Button Replacement: adım 3, 1 resimden 1.
    • Remove two 15mm Phillips #1 screws from the handle.
  4. Hoover LiNX Power Button Replacement: adım 4, 2 resimden 1. Hoover LiNX Power Button Replacement: adım 4, 2 resimden 2.
    • Use a plastic opening tool to carefully pry the black cover off of the handle.
  5. Hoover LiNX Power Button Replacement: adım 5, 2 resimden 1. Hoover LiNX Power Button Replacement: adım 5, 2 resimden 2.
    • Remove five 15mm Phillips #1 black screws from the handle.
  6. Hoover LiNX Power Button Replacement: adım 6, 2 resimden 1. Hoover LiNX Power Button Replacement: adım 6, 2 resimden 2.
    • Remove the silver plastic cover using the plastic opening tool.
  7. Hoover LiNX Power Button Replacement, The Motherboard Inside The Handle: adım 7, 1 resimden 1.
    • Remove the black rubber cover from the motherboard.
  8. Hoover LiNX Power Button Replacement: adım 8, 1 resimden 1.
    • Remove two 8mm Phillips #1 screws from the motherboard.
  9. Hoover LiNX Power Button Replacement: adım 9, 2 resimden 1. Hoover LiNX Power Button Replacement: adım 9, 2 resimden 2.
    • Carefully pull the motherboard out with its attached wires.
  10. Hoover LiNX Power Button Replacement, Power Button: adım 10, 2 resimden 1. Hoover LiNX Power Button Replacement, Power Button: adım 10, 2 resimden 2.
    • Replace the power button.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Mark Nelson
452 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S7-G4, Passmore Spring 2018 USF Tampa, Team S7-G4, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S7G4
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 22
Her zaman: 1,523
