Giriş
This guide will show you how to open dissemble the handle and replace the motherboard. You might need to do this if the device has power but fails to turn on. Remember to remove the battery from the device.
Neye ihtiyacın var
Remove the single 15mm Phillips #1 screw from the handle.
Remove the black rubber cover from the motherboard.
Bir başkası bu kılavuzu tamamladı.
