Ana içeriğe geç
Hoover LiNX The Motherboard Inside The Handle Replacement
Neye ihtiyacın var
  1. Hoover LiNX The Motherboard Inside The Handle  Replacement, Hoover LiNX Handle Teardown: adım 1, 1 resimden 1.
    • Remove the single 15mm Phillips #1 screw from the handle.
  2. Hoover LiNX The Motherboard Inside The Handle  Replacement: adım 2, 1 resimden 1.
    • Remove the handle by pulling it up.
  3. Hoover LiNX The Motherboard Inside The Handle  Replacement: adım 3, 1 resimden 1.
    • Remove two 15mm Phillips #1 screws from the handle.
  4. Hoover LiNX The Motherboard Inside The Handle  Replacement: adım 4, 2 resimden 1. Hoover LiNX The Motherboard Inside The Handle  Replacement: adım 4, 2 resimden 2.
    • Use a plastic opening tool to carefully pry the black cover off of the handle.
  5. Hoover LiNX The Motherboard Inside The Handle  Replacement: adım 5, 2 resimden 1. Hoover LiNX The Motherboard Inside The Handle  Replacement: adım 5, 2 resimden 2.
    • Remove five 15mm Phillips #1 black screws from the handle.
  6. Hoover LiNX The Motherboard Inside The Handle  Replacement: adım 6, 2 resimden 1. Hoover LiNX The Motherboard Inside The Handle  Replacement: adım 6, 2 resimden 2.
    • Remove the silver plastic cover using the plastic opening tool.
  7. Hoover LiNX The Motherboard Inside The Handle  Replacement, The Motherboard Inside The Handle: adım 7, 1 resimden 1.
    • Remove the black rubber cover from the motherboard.
  8. Hoover LiNX The Motherboard Inside The Handle  Replacement: adım 8, 1 resimden 1.
    • Remove two 8mm Phillips #1 screws from the motherboard.
  9. Hoover LiNX The Motherboard Inside The Handle  Replacement: adım 9, 2 resimden 1. Hoover LiNX The Motherboard Inside The Handle  Replacement: adım 9, 2 resimden 2.
    • Carefully pull the motherboard out with its attached wires.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sara Vlhova
541 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S7-G4, Passmore Spring 2018 USF Tampa, Team S7-G4, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S7G4
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 15
Her zaman: 902
