Ana içeriğe geç
Hoover LiNX The Nozzle Prongs Replacement
Neye ihtiyacın var
  1. Hoover LiNX The Nozzle Prongs Replacement, Replace The Motor: adım 1, 1 resimden 1.
    • Detach the rolling assembly from the body by pushing the button found at the base.
  2. Hoover LiNX The Nozzle Prongs Replacement: adım 2, 1 resimden 1.
    • Remove the seven 7.5mm Phillips #1 screws from the brush retainer.
  3. Hoover LiNX The Nozzle Prongs Replacement: adım 3, 2 resimden 1. Hoover LiNX The Nozzle Prongs Replacement: adım 3, 2 resimden 2.
    • Remove the brush and retainer from the rolling assembly.
    • The brush will need to be disconnected from the belt.
  4. Hoover LiNX The Nozzle Prongs Replacement: adım 4, 1 resimden 1.
    • Remove the eight 4mm Phillips #1 screws from the bottom panel.
  5. Hoover LiNX The Nozzle Prongs Replacement: adım 5, 1 resimden 1.
    • Remove the bottom panel.
  6. Hoover LiNX The Nozzle Prongs Replacement: adım 6, 1 resimden 1.
    • Remove the motor.
  7. Hoover LiNX The Nozzle Prongs Replacement, The Nozzle Prongs: adım 7, 1 resimden 1.
    • Remove the two 7.5mm Phillips #1 screws from the main body.
  8. Hoover LiNX The Nozzle Prongs Replacement: adım 8, 1 resimden 1.
    • Remove the black covering from the air tube.
  9. Hoover LiNX The Nozzle Prongs Replacement: adım 9, 1 resimden 1.
    • Slide the prongs out through their channels.
  10. Hoover LiNX The Nozzle Prongs Replacement: adım 10, 2 resimden 1. Hoover LiNX The Nozzle Prongs Replacement: adım 10, 2 resimden 2.
    • Remove the angled neck and feed the prongs out through their channels.
  11. Hoover LiNX The Nozzle Prongs Replacement: adım 11, 2 resimden 1. Hoover LiNX The Nozzle Prongs Replacement: adım 11, 2 resimden 2.
    • Replace the prongs.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Sara Vlhova
541 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S7-G4, Passmore Spring 2018 USF Tampa, Team S7-G4, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S7G4
4 Üyeler
12 adet Kılavuz yazıldı
2 Yorum
How do I get to the receivers for the prongs? They appear to be too loose to make a connection and i have not been able to get into the body to tighten. Is there another way to improve this connection?
Robert L Worthing - Yanıt
Thank you for asking ifixit your 11/1018 question. I’ve been trying to disassemble the body to get at the receiver(s)/socket(s) for those prongs for days. And ifixit, please, have you got a picture of the routing of the brush motor wires from the motor through the rolling assembly, the swiveling universal joint, and along the back of the airtube?
donwesel - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 18
Son 30 gün: 38
Her zaman: 1,723
