Ana içeriğe geç
Hoover LiNX Wheel Replacement
Neye ihtiyacın var
  1. Hoover LiNX Wheel Replacement, Replace The Motor: adım 1, 1 resimden 1.
    • Detach the rolling assembly from the body by pushing the button found at the base.
  2. Hoover LiNX Wheel Replacement: adım 2, 1 resimden 1.
    • Remove the seven 7.5mm Phillips #1 screws from the brush retainer.
  3. Hoover LiNX Wheel Replacement: adım 3, 2 resimden 1. Hoover LiNX Wheel Replacement: adım 3, 2 resimden 2.
    • Remove the brush and retainer from the rolling assembly.
    • The brush will need to be disconnected from the belt.
  4. Hoover LiNX Wheel Replacement: adım 4, 1 resimden 1.
    • Remove the eight 4mm Phillips #1 screws from the bottom panel.
  5. Hoover LiNX Wheel Replacement: adım 5, 1 resimden 1.
    • Remove the bottom panel.
  6. Hoover LiNX Wheel Replacement: adım 6, 1 resimden 1.
    • Remove the motor.
  7. Hoover LiNX Wheel Replacement, Wheel: adım 7, 2 resimden 1. Hoover LiNX Wheel Replacement, Wheel: adım 7, 2 resimden 2.
    • Remove the black plastic clamp from inside the wheel axle.
  8. Hoover LiNX Wheel Replacement: adım 8, 3 resimden 1. Hoover LiNX Wheel Replacement: adım 8, 3 resimden 2. Hoover LiNX Wheel Replacement: adım 8, 3 resimden 3.
    • Remove broken wheel and replace.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sara Vlhova
541 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S7-G4, Passmore Spring 2018 USF Tampa, Team S7-G4, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S7G4
4 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
where can i buy these rubber wheels ? They worn out fast.
The Glider Flyer - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 1,468
