Ana içeriğe geç
Hoover Power Path Pro Advanced Power Switch Replacement
Neye ihtiyacın var
    1. Hoover Power Path Pro Advanced Power Switch Replacement, Power Switch: adım 1, 1 resimden 1.
      • Remove the lower brushroll from the bottom of the cleaner.
      FixBot'a Sor
      Yorum Ekle
    2. Hoover Power Path Pro Advanced Power Switch Replacement: adım 2, 1 resimden 1.
      • Use a long #2 Philips head to remove the 8 numbered screws on the bottom of the cleaner (They will also be indicated on the bottom of the vacuum).
      FixBot'a Sor
      Yorum Ekle
    3. Hoover Power Path Pro Advanced Power Switch Replacement: adım 3, 2 resimden 1. Hoover Power Path Pro Advanced Power Switch Replacement: adım 3, 2 resimden 2.
      • Pull the red handle to remove the front suction unit from the cleaner.
      FixBot'a Sor
      Yorum Ekle
    4. Hoover Power Path Pro Advanced Power Switch Replacement: adım 4, 1 resimden 1.
      • Unscrew the hose by using a Phillips #2 to detach it from the top cover of the cleaner.
      FixBot'a Sor
      Yorum Ekle
    5. Hoover Power Path Pro Advanced Power Switch Replacement: adım 5, 2 resimden 1. Hoover Power Path Pro Advanced Power Switch Replacement: adım 5, 2 resimden 2.
      • Push down on the handle release button. Lift the edge of top cover connected to this button.
      • Repeat the above step for the "On/Off" button.
      • Pull entire top cover off.
      • Caution: when pulling the handle release button, make sure the top of the cleaner does not fall.
      FixBot'a Sor
      Yorum Ekle
    6. Hoover Power Path Pro Advanced Power Switch Replacement: adım 6, 1 resimden 1.
      • Remove the "On/Off" cap by pulling it upwards with caution.
      FixBot'a Sor
      Yorum Ekle
    7. Hoover Power Path Pro Advanced Power Switch Replacement: adım 7, 1 resimden 1.
      • Use a long #2 Philips head to remove the two screws from the arched grey piece.
      FixBot'a Sor
      Yorum Ekle
    8. Hoover Power Path Pro Advanced Power Switch Replacement: adım 8, 2 resimden 1. Hoover Power Path Pro Advanced Power Switch Replacement: adım 8, 2 resimden 2.
      • Pull out the red power the red power switch.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Ekip
Cal Poly, Team S16-G5, Banghart Winter 2018 Cal Poly, Team S16-G5, Banghart Winter 2018 üyesi
CPSU-BANGHART-W18S16G5
5 Üyeler
50 adet Kılavuz yazıldı
3Kılavuz Yorumları
What is the part number?
martahayner - Yanıt Paylaş
Thanks so much!!
debmccrimm - Yanıt Paylaş
you have to test the switch, mine tested ok which led me to the fuse between the motor and switch. It was bad, parts warehouse part # 440004065 does the trick.
frank - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 44
Her zaman: 4,353
