Ana içeriğe geç
Hoover Presto 2-in-1 Cordless Stick Charger Replacement
Neye ihtiyacın var
  1. Hoover Presto 2-in-1 Cordless Stick Charger Replacement, Charger Electronic Module: adım 1, 3 resimden 1. Hoover Presto 2-in-1 Cordless Stick Charger Replacement, Charger Electronic Module: adım 1, 3 resimden 2. Hoover Presto 2-in-1 Cordless Stick Charger Replacement, Charger Electronic Module: adım 1, 3 resimden 3.
    • Using a firm grip, gently pull the standing charger away from the floor charger attachment
  2. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: adım 2, 2 resimden 1. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: adım 2, 2 resimden 2.
    • Flip the floor charger over so the screws and sticker are facing you
    • Using a PH #1 screw driver, remove the two 18mm screws on the right hand side of the floor charger
  3. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: adım 3, 2 resimden 1. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: adım 3, 2 resimden 2.
    • Using a PH #2 screw driver, remove the three 18mm screws on floor charger.
  4. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: adım 4, 2 resimden 1. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: adım 4, 2 resimden 2.
    • Using the metal spudger tool, gently lift up the plastic cover in the upper right hand corner of the floor attachment to uncover a hidden screw
    • Remove the 18mm screw in the upper right hand corner with a PH #1 screw driver
  5. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: adım 5, 2 resimden 1. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: adım 5, 2 resimden 2.
    • Using the metal spudger, gently pry open the two halves of the floor charger
    • Once you have made a larger enough gap between the two halves, use your hands and gently pull the rest of the floor charger apart
  6. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: adım 6, 1 resimden 1.
    • Unscrew the two 18mm screws on either side of the white battery cover with a PH #1 screw driver
  7. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: adım 7, 2 resimden 1. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: adım 7, 2 resimden 2.
    • Using your hands, gently pull apart the two halves of the white battery cover to get to the battery
Sonuç
Bir başkası bu kılavuzu tamamladı.
katia zubieta
437 İtibar
4 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team S2-G6, Bruce Fall 2017 CSU Fullerton, Team S2-G6, Bruce Fall 2017 üyesi
CSUF-BRUCE-F17S2G6
3 Üyeler
8 adet Kılavuz yazıldı
4 Yorum
La pila dónde la puedo encontrar
alejandro rodriguez - Yanıt
De la aspiradora Hoover presto 2 un 1
I followed the directions above and got it opened. There was no battery inside. What do I do???? This is for the Hoover Presto 2in1. Thank you.
silvmarg - Yanıt
Where does one buy the replacement battery?
mytikikitty - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 28
Her zaman: 6,085
