Ana içeriğe geç
Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement
  1. Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement, HEPA Filter: adım 1, 3 resimden 1. Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement, HEPA Filter: adım 1, 3 resimden 2. Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement, HEPA Filter: adım 1, 3 resimden 3.
    • Using your hands, gently pull the hand vacuum away from the stick vacuum to detach.
  2. Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: adım 2, 2 resimden 1. Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: adım 2, 2 resimden 2.
    • Press the hand vacuum's gray release button located directly below the power button to release the dust container from the hand vacuum.
    • Gently pull off the dust container with your other hand.
  3. Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: adım 3, 2 resimden 1. Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: adım 3, 2 resimden 2.
    • Remove HEPA filter from dust pan by pulling gently.
  4. Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: adım 4, 2 resimden 1. Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: adım 4, 2 resimden 2.
    • Separate the cyclonic separator from the HEPA filter by pulling apart.
  5. Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: adım 5, 2 resimden 1. Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: adım 5, 2 resimden 2.
    • Hold the HEPA dust filter over trash bin and gently shake to clean. Use hands to rub off dirt/dust if necessary.
Sonuç
Bir başkası bu kılavuzu tamamladı.
katia zubieta
437 İtibar
4 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team S2-G6, Bruce Fall 2017 CSU Fullerton, Team S2-G6, Bruce Fall 2017 üyesi
CSUF-BRUCE-F17S2G6
3 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
Necesito bateria hoover presto 2 en 1 14.4v 1400 mah
cpeza - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 661
