Ana içeriğe geç
Hoover Presto 2-in-1 Cordless Stick Rotating Brush Roll Replacement
Neye ihtiyacın var
  1. Hoover Presto 2-in-1 Cordless Stick Rotating Brush Roll Replacement, Rotating Brush Roll: adım 1, 2 resimden 1. Hoover Presto 2-in-1 Cordless Stick Rotating Brush Roll Replacement, Rotating Brush Roll: adım 1, 2 resimden 2.
    • Press grey release button on stick vacuum to release vacuum head.
  2. Hoover Presto 2-in-1 Cordless Stick Rotating Brush Roll Replacement: adım 2, 3 resimden 1. Hoover Presto 2-in-1 Cordless Stick Rotating Brush Roll Replacement: adım 2, 3 resimden 2. Hoover Presto 2-in-1 Cordless Stick Rotating Brush Roll Replacement: adım 2, 3 resimden 3.
    • Locate the circular black turn switch, which is in the upper right corner of the backside of the vacuum head
    • Using a metal spudger, place the tool in the indent of the circular turn switch and turn it from the left to the right or from the "locked" symbol to the "unlocked" symbol
  3. Hoover Presto 2-in-1 Cordless Stick Rotating Brush Roll Replacement: adım 3, 2 resimden 1. Hoover Presto 2-in-1 Cordless Stick Rotating Brush Roll Replacement: adım 3, 2 resimden 2.
    • Flip the vacuum head over so that the wheels and screws are facing you.
    • Using a PH #1 screw driver, remove the four 15mm screws from each corner of the backside of the vacuum head.
  4. Hoover Presto 2-in-1 Cordless Stick Rotating Brush Roll Replacement: adım 4, 3 resimden 1. Hoover Presto 2-in-1 Cordless Stick Rotating Brush Roll Replacement: adım 4, 3 resimden 2. Hoover Presto 2-in-1 Cordless Stick Rotating Brush Roll Replacement: adım 4, 3 resimden 3.
    • Locate the two wheels in the upper half of the vacuum head and remove them by sticking the metal spudger tool underneath the wheel and pushing it towards you until it pops out.
    • Remove the two 15mm screws located under the wheels with a PH #1 screw driver.
  5. Hoover Presto 2-in-1 Cordless Stick Rotating Brush Roll Replacement: adım 5, 3 resimden 1. Hoover Presto 2-in-1 Cordless Stick Rotating Brush Roll Replacement: adım 5, 3 resimden 2. Hoover Presto 2-in-1 Cordless Stick Rotating Brush Roll Replacement: adım 5, 3 resimden 3.
    • Using a firm grip, pull the two halves of the vacuum head away from each other until they are completely separated
  6. Hoover Presto 2-in-1 Cordless Stick Rotating Brush Roll Replacement: adım 6, 1 resimden 1.
    • Remove brush from inside the vacuum head.
Sonuç
katia zubieta
437 İtibar
4 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team S2-G6, Bruce Fall 2017 CSU Fullerton, Team S2-G6, Bruce Fall 2017 üyesi
CSUF-BRUCE-F17S2G6
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 599
