Ana içeriğe geç
Hoover Rogue 970 Battery Replacement
Neye ihtiyacın var
    1. Hoover Rogue 970 Battery Replacement, Battery: adım 1, 2 resimden 1. Hoover Rogue 970 Battery Replacement, Battery: adım 1, 2 resimden 2.
      • Flip the vacuum over so that the battery cover is facing up.
      • Locate the battery cover.
      FixBot'a Sor
      Yorum Ekle
    2. Hoover Rogue 970 Battery Replacement: adım 2, 1 resimden 1.
      • Remove the two 14.7 mm screws using a Phillips #0 screwdriver.
      • Lift the battery cover up to remove it from the vacuum.
      FixBot'a Sor
      Yorum Ekle
    3. Hoover Rogue 970 Battery Replacement: adım 3, 3 resimden 1. Hoover Rogue 970 Battery Replacement: adım 3, 3 resimden 2. Hoover Rogue 970 Battery Replacement: adım 3, 3 resimden 3.
      • If the battery is swollen look here for safety practices.
      • Lift the battery out of the vacuum to access the connected white tab.
      • Disconnect the JST connector that attaches the battery to the vacuum.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 585
