Giriş
This guide is for the Hoover Rogue 970 (Model BH70970) Smart Vacuum.
Are your Hoover Rouge 970 wheels stuck, unable to rotate, or preventing the whole vacuum from moving? If so, here is the guide to fix the problem with a simple change of the wheels.
Neye ihtiyacın var
Press the buttons on the brush roll cover inward.
Gently pull the brush roll cover away from the vacuum.
Locate wheel assembly.
Remove the five 8.7 mm screws using a Phillips #0 screwdriver.
