Ana içeriğe geç
Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement
Neye ihtiyacın var
  1. Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement, Brush Roll: adım 1, 3 resimden 1. Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement, Brush Roll: adım 1, 3 resimden 2. Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement, Brush Roll: adım 1, 3 resimden 3.
    • Push the red release lever to the right.
    • Turn the red switch counterclockwise.
    • Tilt the bottom of the plastic tray out towards you and pull it off the vacuum.
  2. Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement: adım 2, 1 resimden 1.
    • Pull the brush roll out of vacuum.
    • Remove the belt from brush roller
Sonuç
Sophia Stockburger
566 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S11-G2, Banghart Winter 2018 Cal Poly, Team S11-G2, Banghart Winter 2018 üyesi
CPSU-BANGHART-W18S11G2
5 Üyeler
9 adet Kılavuz yazıldı
3 Yorum
When you turn the vacuum on the brush roller works until you release the handle to start vacuuming then the brush roller stops. How do I correct this issue?
Brenda Brenda - Yanıt
Did you ever get an answer on this issue or figure it out? I am having the same problem!
Val -
Mine does the same thing. I have replaced the belt but that didn’t help
Ann - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 17
Her zaman: 996
