Ana içeriğe geç
Hoover WindTunnel 2 Rewind Belt and Roller Brush Replacement
Neye ihtiyacın var
  1. Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement, Belt and Roller Brush: adım 1, 2 resimden 1. Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement, Belt and Roller Brush: adım 1, 2 resimden 2.
    • Remove the four 20 mm Phillips #1 head screws holding the top cover on.
    • Lift off the cover.
  2. Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement: adım 2, 1 resimden 1.
    • Grab on both ends of the roller brush, lifting it and the attached belt clear of the housing.
  3. Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement: adım 3, 2 resimden 1. Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement: adım 3, 2 resimden 2.
    • Reinstall belt and roller making sure that the white text is facing outwards on the belt.
    • Placing the roller brush in its guides will put some tension on the belt after the roller is in place spin it with your hand a couple times to ensure that it spins freely.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Thomas Eggenberger
139 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S11-G4, Banghart Winter 2018 Cal Poly, Team S11-G4, Banghart Winter 2018 üyesi
CPSU-BANGHART-W18S11G4
5 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
Thank you, made it easy peasy!
J Colee - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 23
Son 30 gün: 113
Her zaman: 8,887
