Ana içeriğe geç
Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement
Neye ihtiyacın var
  1. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement, Primary Air Filter: adım 1, 1 resimden 1.
    • Press button on the top of the dust cup and pull back.
    • Remove dust cup from vacuum
  2. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: adım 2, 1 resimden 1.
    • Pull back on black lever and rotate dust cup lid back.
  3. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: adım 3, 1 resimden 1.
    • Lift up on fabric flap to remove filter from vaccum
    • If you wish to clean the filter rather than replace it, it can be washed under a faucet.
    • If washing the filter, make sure it fully dries out before re-installing.
  4. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement, Dust Cup Assembly: adım 4, 1 resimden 1.
    • Holding onto both the top handle and dust cup body, twist the two components apart following the instructions printed on the back.
  5. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: adım 5, 2 resimden 1. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: adım 5, 2 resimden 2.
    • Unscrew the three 4 cm Phillips #3 screws located inside the dust filter compartment to detach the dust filter system.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Chino Cruz
135 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S11-G4, Banghart Winter 2018 Cal Poly, Team S11-G4, Banghart Winter 2018 üyesi
CPSU-BANGHART-W18S11G4
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 52
Her zaman: 4,778
