Ana içeriğe geç
Hoover WindTunnel 2 Rewind Leaky Hose Replacement
Neye ihtiyacın var
  1. Hoover WindTunnel 2 Rewind Leaky Hose Replacement, Leaky Hose: adım 1, 1 resimden 1.
    • Detach the top of the hose from the device by pressing the release button and pulling up on the hose.
  2. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: adım 2, 1 resimden 1.
    • Remove the other end of the hose by twisting the hose clockwise and pulling it off.
  3. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: adım 3, 1 resimden 1.
    • Firmly insert the larger end of the replacement hose into the upward facing hole in the vacuum.
  4. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: adım 4, 1 resimden 1.
    • Line up the smaller end of the hose and insert it into the downward facing hole.
    • Twist the hose until it locks.
Sonuç
The Hoover Windtunnel 2 Rewind must have a solid and functional hose to work correctly. With this set of instructions, it is easy to replace a leaky hose.
6 farklı kişi bu kılavuzu tamamladı.
Mickey McGuire
253 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S11-G4, Banghart Winter 2018 Cal Poly, Team S11-G4, Banghart Winter 2018 üyesi
CPSU-BANGHART-W18S11G4
5 Üyeler
10 adet Kılavuz yazıldı
6 Yorum
Good job, helpful. Thanks!
Celeste Williams-Hughes - Yanıt
Thanks, I'm stuck in quarantine and can't go out to get mine fixed, so I'm so glad I found this. Especially since it was just my hose being filled to the brim with dog hair!
Taylore Kirk - Yanıt
Same issue. Easy fix thanks!
mark camirand - Yanıt
That’s great instructions but it’s not even 8 months old. This has happened from day one!!
Linda Schindler - Yanıt
How long does it take to cool off and turn back on after removing the clog?
Victoria Tingwall - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 27
Son 30 gün: 132
Her zaman: 28,281
