Ana içeriğe geç
Hoover WindTunnel 2 Rewind Leaky Hose Replacement
Neye ihtiyacın var
  1. Hoover WindTunnel 2 Rewind Leaky Hose Replacement, Leaky Hose: adım 1, 1 resimden 1.
    • Detach the top of the hose from the device by pressing the release button and pulling up on the hose.
  2. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: adım 2, 1 resimden 1.
    • Remove the other end of the hose by twisting the hose clockwise and pulling it off.
  3. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: adım 3, 1 resimden 1.
    • Firmly insert the larger end of the replacement hose into the upward facing hole in the vacuum.
  4. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: adım 4, 1 resimden 1.
    • Line up the smaller end of the hose and insert it into the downward facing hole.
    • Twist the hose until it locks.
Sonuç
The Hoover Windtunnel 2 Rewind must have a solid and functional hose to work correctly. With this set of instructions, it is easy to replace a leaky hose.
6 farklı kişi bu kılavuzu tamamladı.
Mickey McGuire
253 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S11-G4, Banghart Winter 2018 Cal Poly, Team S11-G4, Banghart Winter 2018 üyesi
CPSU-BANGHART-W18S11G4
5 Üyeler
10 adet Kılavuz yazıldı
6 Yorum
Good job, helpful. Thanks!
Celeste Williams-Hughes - Yanıt
Thanks, I'm stuck in quarantine and can't go out to get mine fixed, so I'm so glad I found this. Especially since it was just my hose being filled to the brim with dog hair!
Taylore Kirk - Yanıt
Same issue. Easy fix thanks!
mark camirand - Yanıt
That’s great instructions but it’s not even 8 months old. This has happened from day one!!
Linda Schindler - Yanıt
How long does it take to cool off and turn back on after removing the clog?
Victoria Tingwall - Yanıt
I took the hose off and unclogged it but the vacuum still isn't turning back on, is there something else that may cause it to not work, or is it because the motor still needs to cool, and how long until it cools?
rpottle - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 28
Son 30 gün: 143
Her zaman: 27,888
