Ana içeriğe geç
Hoover WindTunnel 2 Rewind Primary Air Filter Replacement
Neye ihtiyacın var
  1. Hoover WindTunnel 2 Rewind Primary Air Filter Replacement, Primary Air Filter: adım 1, 1 resimden 1.
    • Press button on the top of the dust cup and pull back.
    • Remove dust cup from vacuum
  2. Hoover WindTunnel 2 Rewind Primary Air Filter Replacement: adım 2, 1 resimden 1.
    • Pull back on black lever and rotate dust cup lid back.
  3. Hoover WindTunnel 2 Rewind Primary Air Filter Replacement: adım 3, 1 resimden 1.
    • Lift up on fabric flap to remove filter from vaccum
    • If you wish to clean the filter rather than replace it, it can be washed under a faucet.
    • If washing the filter, make sure it fully dries out before re-installing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Joshua Anderson
268 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S11-G4, Banghart Winter 2018 Cal Poly, Team S11-G4, Banghart Winter 2018 üyesi
CPSU-BANGHART-W18S11G4
5 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
Can I rinse it with warm water and soap? Or just warm water?
lacey sodapop - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 28
Her zaman: 2,518
