Ana içeriğe geç
Hoover Windtunnel Air Steerable Upright Motor Assembly Replacement
Neye ihtiyacın var
  1. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, HEPA Filter: adım 1, 2 resimden 1. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, HEPA Filter: adım 1, 2 resimden 2.
    • Put the cleaner into the upright position, turn the power off, and unplug the power cord.
  2. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: adım 2, 3 resimden 1. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: adım 2, 3 resimden 2. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: adım 2, 3 resimden 3.
    • Remove the dirt cup from the cleaner.
    • The HEPA filter is located under the dirt cup and under where it says HEPA.
    • Twist the top counterclockwise to unlock the cap.
  3. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: adım 3, 2 resimden 1. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: adım 3, 2 resimden 2.
    • Lift the HEPA filter out.
    • Tap the filter against the inside of a trashcan to knock out the dirt and debris or replace as necessary.
    • Do not wash the HEPA Filter.
  4. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, Motor Assembly: adım 4, 3 resimden 1. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, Motor Assembly: adım 4, 3 resimden 2. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, Motor Assembly: adım 4, 3 resimden 3.
    • Remove the 4 retaining screws and remove the filter tray.
    • Screw lengths are approximately 3/4".
  5. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: adım 5, 1 resimden 1.
    • Pull the motor housing vertically to dislodge the motor.
  6. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: adım 6, 3 resimden 1. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: adım 6, 3 resimden 2. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: adım 6, 3 resimden 3.
    • Use a plastic spudger or opening tool to press on the small circle and wiggle clips free.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
steven hoover
257 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G2, Banghart Fall 2017 Cal Poly, Team S7-G2, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S7G2
5 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 43
Her zaman: 3,979
