Giriş
This guide will demonstrate proper removal of old or broken wheels and replacement with new wheels
Neye ihtiyacın var
Lay the vacuum flat on the ground, then flip it over 180 degrees so that you can see the inside of the wheel.
Take the needle nose pliers and stick them in the rectangular hole.
With the pliers, firmly grasp the metal pin that holds the bolt for the wheel in place.
Slide the pin off the bolt by pushing the pliers forward.
Carefully remove the pin from the rectangular hole and keep it in a safe place.
Neredeyse bitti!
Bitiş Çizgisi
