Ana içeriğe geç
Hot Tools HPK12 Control Assembly Replacement
Neye ihtiyacın var
    1. Hot Tools HPK12 Control Assembly Replacement, Prerequisite Only: adım 1, 3 resimden 1. Hot Tools HPK12 Control Assembly Replacement, Prerequisite Only: adım 1, 3 resimden 2. Hot Tools HPK12 Control Assembly Replacement, Prerequisite Only: adım 1, 3 resimden 3.
      • Remove round plastic cover near cord base by prying under the side with the metal spudger.
      • Flip the device and remove the other round plastic cover near the base of the cord.
      • Use the Phillips #1 screwdriver to remove the 5.5mm PH1 screw and washer under the plastic cover and set both aside.
      FixBot'a Sor
      Yorum Ekle
    2. Hot Tools HPK12 Control Assembly Replacement: adım 2, 1 resimden 1.
      • Use the metal spudger to push the center pin through to the other side.
      FixBot'a Sor
      Yorum Ekle
    3. Hot Tools HPK12 Control Assembly Replacement: adım 3, 2 resimden 1. Hot Tools HPK12 Control Assembly Replacement: adım 3, 2 resimden 2.
      • Lift back plastic cover to expose spring assembly.
      • Be careful not to damage the power cord by bending or twisting it too much while performing this step.
      • Grip the exposed end of the spring assembly and remove it.
      • The side with the two ends of the spring goes into the recessed area of the iron
      FixBot'a Sor
      Yorum Ekle
    4. Hot Tools HPK12 Control Assembly Replacement: adım 4, 1 resimden 1.
      • Use the JIS #0 screwdriver to remove the two 3.5mm “J0” screws that attach the control assembly cover to the flat iron base.
      FixBot'a Sor
      Yorum Ekle
    5. Hot Tools HPK12 Control Assembly Replacement: adım 5, 3 resimden 1. Hot Tools HPK12 Control Assembly Replacement: adım 5, 3 resimden 2. Hot Tools HPK12 Control Assembly Replacement: adım 5, 3 resimden 3.
      • Lift upward on the control assembly cover to remove it from the flat iron base.
      • Remove dial and switch cover and set aside.
      FixBot'a Sor
      Yorum Ekle
    6. Hot Tools HPK12 Control Assembly Replacement: adım 6, 3 resimden 1. Hot Tools HPK12 Control Assembly Replacement: adım 6, 3 resimden 2. Hot Tools HPK12 Control Assembly Replacement: adım 6, 3 resimden 3.
      • Use your JIS #0 screw driver to remove the two 6mm “J0” screws that are attached to the flat iron base and set them aside.
      • Lift the backing plate upwards to remove it from the flat iron.
      • Use the Phillips #0 screwdriver to remove two 4mm “PH0” screws that attach the circuit assembly to the flat iron base.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Aaron Whitlock
249 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-4, Baechle Fall 2016 IUPUI, Team 3-4, Baechle Fall 2016 üyesi
IUPUI-BAECHLE-F16S3G4
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 32
Her zaman: 3,221
