Ana içeriğe geç
Hot Wheels AI Intelligent Race System Controller Transmitter Replacement
Neye ihtiyacın var
  1. Hot Wheels AI Intelligent Race System Controller Transmitter Replacement, Controller Transmitter: adım 1, 1 resimden 1.
    • Locate and remove the six screws on the back of the controller. Remove screws with a #J1 Philips head screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Hot Wheels AI Intelligent Race System Controller Transmitter Replacement: adım 2, 1 resimden 1.
    • With the controller facing down remove the top casing from the bottom. Do this by popping the casing lose which will expose the inside circuits.
    FixBot'a Sor
    Yorum Ekle
  3. Hot Wheels AI Intelligent Race System Controller Transmitter Replacement: adım 3, 1 resimden 1.
    • With the circuits exposed locate the transmitter at the top of the controller. It is green hue in comparison to the rest of the blue circuits. Check the transmitter for damage or disconnected wires.
    FixBot'a Sor
    Yorum Ekle
  4. Hot Wheels AI Intelligent Race System Controller Transmitter Replacement: adım 4, 1 resimden 1.
    • If transmitter has broken or has disconnected wires it may need replacement. Wires can easily break loose from the transmitter. The wires can easily be reinserted by sticking the wire back into its original slot.
    FixBot'a Sor
    Yorum Ekle
  5. Hot Wheels AI Intelligent Race System Controller Transmitter Replacement: adım 5, 1 resimden 1.
    • If the transmitter is damaged, replace it by sliding the circuit down from its slot. Check for damage or burned out circuit.
    • Replace transmitter circuit with a new one by reinserting it into the original slot.
    FixBot'a Sor
    Yorum Ekle
Sonuç
1Rehber Yorum
Give the part numbers so we can source the circuits and change the devices if needed. Also can anyone extract the rim? I believe the rim being used is way low quality.
Luis Vitorio Cargnini - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 51
Her zaman: 1,422
