Ana içeriğe geç
Hott T725-8G Battery Replacement
Neye ihtiyacın var
    1. Hott T725-8G Battery Replacement, Back Panel: adım 1, 1 resimden 1.
      • Remove the back of the device using the Plastic Opening tool by placing it between the front and back panel and gently prying them apart.
      FixBot'a Sor
      Yorum Ekle
    2. Hott T725-8G Battery Replacement: adım 2, 1 resimden 1.
      • Once the Plastic Opening tool has separated the halves, use your hands to pull them completely apart.
      • Be careful when doing this - the speaker is attached to the back panel and has wires running to the motherboard in the front panel.
      FixBot'a Sor
      Yorum Ekle
    3. Hott T725-8G Battery Replacement: adım 3, 1 resimden 1.
      • Carefully dislodge the speaker from the back panel.
      FixBot'a Sor
      Yorum Ekle
    1. Hott T725-8G Battery Replacement, Battery: adım 4, 1 resimden 1.
      • Remove the yellow tape holding the wire connecting the battery to the motherboard with your fingers.
      FixBot'a Sor
      Yorum Ekle
    2. Hott T725-8G Battery Replacement: adım 5, 1 resimden 1.
      • Use your fingers to separate the ribbon wire from the battery and the back of the display.
      FixBot'a Sor
      Yorum Ekle
    3. Hott T725-8G Battery Replacement: adım 6, 1 resimden 1.
      • Use your fingers to remove more yellow tape holding down the wire connecting the battery to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. Hott T725-8G Battery Replacement: adım 7, 1 resimden 1.
      • You can check one of the connection points between the battery and the motherboard to see if it is firmly connected (which it should be) using the plastic Spudger. It is not necessary to remove this wire to replace the battery.
      FixBot'a Sor
      Yorum Ekle
    5. Hott T725-8G Battery Replacement: adım 8, 1 resimden 1.
      • Use a Plastic Spudger to separate the adhesive side of the battery from the back of the display.
      • Avoid using metal when working with batteries.
      • The adhesive is extremely sticky, but will separate. Ensure that the battery doesn't bend or fold while removing it.
      FixBot'a Sor
      Yorum Ekle
    6. Hott T725-8G Battery Replacement: adım 9, 1 resimden 1.
      • You may use the plastic Spudger to separate the connections between the battery and motherboard. The new battery is now ready to be soldered on.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Emma Carroll
220 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-2, Martin Fall 2016 UMass Dartmouth, Team 6-2, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S6G2
3 Üyeler
23 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 38
Her zaman: 708
