Ana içeriğe geç
Hott T725-8G Speaker Replacement
Neye ihtiyacın var
  1. Hott T725-8G Speaker Replacement, Speaker: adım 1, 1 resimden 1.
    • Gently dislodge the speaker from the back panel so that it is only connected to the motherboard.
  2. Hott T725-8G Speaker Replacement: adım 2, 1 resimden 1.
    • You can check the connection point between the speaker and the motherboard to see if it is firmly connected (which it should be) using the plastic Spudger.
    • Detach the wires using the plastic Spudger to replace the speaker.
Sonuç
Emma Carroll
193 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-2, Martin Fall 2016 UMass Dartmouth, Team 6-2, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S6G2
3 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 84
