Ana içeriğe geç
Hover 1 Eclipse Battery Replacement
  1. Hover 1 Eclipse Battery Replacement, Battery: adım 1, 3 resimden 1. Hover 1 Eclipse Battery Replacement, Battery: adım 1, 3 resimden 2. Hover 1 Eclipse Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that surround the edge of the plug side bottom shell piece.
    • Using a Phillips #1 Screwdriver, remove the four 13mm screws that surround the edge of the plug side bottom shell piece.
    • Remove the right side bottom shell piece.
  2. Hover 1 Eclipse Battery Replacement: adım 2, 2 resimden 1. Hover 1 Eclipse Battery Replacement: adım 2, 2 resimden 2.
    • Locate the black and red wires connected by an yellow header, Xt60.
    • This wire connects the battery to the motherboard.
    • Carefully tug on the two sides of the yellow header to disconnect them.
  3. Hover 1 Eclipse Battery Replacement: adım 3, 3 resimden 1. Hover 1 Eclipse Battery Replacement: adım 3, 3 resimden 2. Hover 1 Eclipse Battery Replacement: adım 3, 3 resimden 3.
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that secure the black plastic keeping the battery in place.
    • Carefully remove the black plastic from the hoverboard.
    • Be mindful of the wires surrounding the battery.
  4. Hover 1 Eclipse Battery Replacement: adım 4, 2 resimden 1. Hover 1 Eclipse Battery Replacement: adım 4, 2 resimden 2.
    • Be careful with the wires surrounding the battery when executing this step.
    • The battery is attached to the metal with an adhesive.
    • Firmly grasp the battery and tug on it until it is free from the metal.
Sonuç
Mina Dedijer
545 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S12-G4, Regan Fall 2019 Cal Poly, Team S12-G4, Regan Fall 2019 üyesi
CPSU-REGAN-F19S12G4
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 38
Her zaman: 2,189
