Ana içeriğe geç
Hover 1 Eclipse Bluetooth Speaker Replacement
Neye ihtiyacın var
  1. Hover 1 Eclipse Bluetooth Speaker Replacement, Bluetooth Speaker: adım 1, 3 resimden 1. Hover 1 Eclipse Bluetooth Speaker Replacement, Bluetooth Speaker: adım 1, 3 resimden 2. Hover 1 Eclipse Bluetooth Speaker Replacement, Bluetooth Speaker: adım 1, 3 resimden 3.
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that surround the edge of the plug side bottom shell piece.
    • Using a Phillips #1 Screwdriver, remove the four 13mm screws that surround the edge of the plug side bottom shell piece.
    • Remove the plug side bottom shell piece
  2. Hover 1 Eclipse Bluetooth Speaker Replacement: adım 2, 3 resimden 1. Hover 1 Eclipse Bluetooth Speaker Replacement: adım 2, 3 resimden 2. Hover 1 Eclipse Bluetooth Speaker Replacement: adım 2, 3 resimden 3.
    • within the plug side shell piece, there are two white and pink wires connecting the shell and the motherboard.
    • On the circuit board by the speaker, carefully squeeze and unplug the small white headers that connect the shell piece to the hoverboard body.
    • On the body of the board, follow the wires that connect the lights to the motherboard. Disconnect these wires from the motherboard by squeezing and pulling the small white headers.
    • Now you can fully remove the shell piece.
  3. Hover 1 Eclipse Bluetooth Speaker Replacement: adım 3, 3 resimden 1. Hover 1 Eclipse Bluetooth Speaker Replacement: adım 3, 3 resimden 2. Hover 1 Eclipse Bluetooth Speaker Replacement: adım 3, 3 resimden 3.
    • Using a Phillips #0 Screwdriver, remove the 3 screws holding the speaker to the shell.
    • Lift the speaker out from the casing.
Sonuç
Mina Dedijer
545 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S12-G4, Regan Fall 2019 Cal Poly, Team S12-G4, Regan Fall 2019 üyesi
CPSU-REGAN-F19S12G4
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 14
Her zaman: 342
