Ana içeriğe geç
Hover 1 Eclipse Charging Port Replacement
Neye ihtiyacın var
  1. Hover 1 Eclipse Charging Port Replacement, Charging Port: adım 1, 2 resimden 1. Hover 1 Eclipse Charging Port Replacement, Charging Port: adım 1, 2 resimden 2.
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that surround the edge of the left side bottom shell piece.
    • Using a Phillips #1 Screwdriver, remove the four 13mm screws that surround the edge of the left side bottom shell piece.
    • The order and placement of the 2 types of screws is mirrored for both sides of the bottom shell.
    • Pull back and set aside the left bottom shell halve. This shell half is still wired to rest of the hoverboard.
    FixBot'a Sor
  2. Hover 1 Eclipse Charging Port Replacement: adım 2, 1 resimden 1.
    • Unscrew the ring around the inside section of the charging port.
    FixBot'a Sor
  3. Hover 1 Eclipse Charging Port Replacement: adım 3, 1 resimden 1.
    • Follow the wire back from the charging port to where it plugs into the board.
    • Unplug the wire from the board, and pull it through the ring you previously unscrewed from the charging port.
    FixBot'a Sor
  4. Hover 1 Eclipse Charging Port Replacement: adım 4, 2 resimden 1. Hover 1 Eclipse Charging Port Replacement: adım 4, 2 resimden 2.
    • Pull the charging port and wire attached to it out through the front side of the port.
    • Take the plastic protector off of the charging port.
    FixBot'a Sor
Sonuç
Mina Dedijer
548 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S12-G4, Regan Fall 2019 Cal Poly, Team S12-G4, Regan Fall 2019 üyesi
CPSU-REGAN-F19S12G4
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 41
Her zaman: 1,058
