Ana içeriğe geç
Hover 1 Eclipse Motherboard Replacement
Neye ihtiyacın var
  1. Hover 1 Eclipse Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. Hover 1 Eclipse Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. Hover 1 Eclipse Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Using a Phillips #1 Screwdriver, remove the eight 11mm screws that surround the edge of each shell piece.
    • Using a Phillips #1 Screwdriver, remove the eight 13mm screws that surround the edge of both shell pieces.
    • Remove the right side bottom shell piece.
    FixBot'a Sor
    Yorum Ekle
  2. Hover 1 Eclipse Motherboard Replacement: adım 2, 3 resimden 1. Hover 1 Eclipse Motherboard Replacement: adım 2, 3 resimden 2. Hover 1 Eclipse Motherboard Replacement: adım 2, 3 resimden 3.
    • On the bottom, left side, shell pieces, there are some white and pink wires connecting the shell and the motherboard.
    • On the circuit board by the speaker, carefully squeeze and unplug the small white headers that connect the shell piece to the hoverboard body.
    • Follow the wires that connect the lights to the motherboard. Disconnect these wires from the motherboard by squeezing and pulling the small white headers.
    • Now you can fully remove the bottom left shell piece.
    FixBot'a Sor
    Yorum Ekle
  3. Hover 1 Eclipse Motherboard Replacement: adım 3, 1 resimden 1.
    • Unplug the yellow tipped plug, Xt60, attached to the red and black cord on the non-battery side.
    FixBot'a Sor
    Yorum Ekle
  4. Hover 1 Eclipse Motherboard Replacement: adım 4, 3 resimden 1. Hover 1 Eclipse Motherboard Replacement: adım 4, 3 resimden 2. Hover 1 Eclipse Motherboard Replacement: adım 4, 3 resimden 3.
    • Unplug the yellow tipped plug attached to the red and black cords.
    • Unplug the black headers attached to the white, skinny cord.
    • Unplug the green, blue and yellow plugs by pressing down the silver, under the clear plastic and pulling it apart.
    FixBot'a Sor
    Yorum Ekle
  5. Hover 1 Eclipse Motherboard Replacement: adım 5, 2 resimden 1. Hover 1 Eclipse Motherboard Replacement: adım 5, 2 resimden 2.
    • Unplug the white header attached to the pink and white cord.
    • Using a Phillips #1 screwdriver, remove the four screws from each corner of the motherboard.
    • Repeat steps 3 and 4 on the other side.
    FixBot'a Sor
    Yorum Ekle
  6. Hover 1 Eclipse Motherboard Replacement: adım 6, 1 resimden 1.
    • You have now removed the motherboards from both sides.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Mina Dedijer
548 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S12-G4, Regan Fall 2019 Cal Poly, Team S12-G4, Regan Fall 2019 üyesi
CPSU-REGAN-F19S12G4
4 Üyeler
5 adet Kılavuz yazıldı
7Kılavuz Yorumları
Can you please drop links to purchase the 2 motherboards?
Frank - Yanıt Paylaş
Hi
wondering if you know the part numbers and where to obtain the boards?
Dave - Yanıt Paylaş
We’re do you get the boards at I really need them
Ashton Mcalvain - Yanıt Paylaş
We’re do get the boards?
Hector Ortiz - Yanıt Paylaş
Any idea where to buy parts and the price?
william bowen - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 45
Her zaman: 2,603
