Ana içeriğe geç
Hover 1 Eclipse Shell Replacement
Neye ihtiyacın var
  1. Hover 1 Eclipse Shell Replacement, Shell: adım 1, 3 resimden 1. Hover 1 Eclipse Shell Replacement, Shell: adım 1, 3 resimden 2. Hover 1 Eclipse Shell Replacement, Shell: adım 1, 3 resimden 3.
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that surround the edge of the plug side bottom shell piece.
    • Using a Phillips #1 Screwdriver, remove the four 13mm screws that surround the edge of the plug side bottom shell piece.
    • Remove the plug side bottom shell piece.
    • Be cautious of the wires connecting the plug side shell piece to the body. Do not pull the piece off until these wires have been disconnected in the following step.
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that surround the edge of the remaining bottom shell piece.
    • Using a Phillips #1 Screwdriver, remove the four 13mm screws that surround the edge of the remaining side bottom shell piece.
    • Remove final bottom shell piece
    FixBot'a Sor
    Yorum Ekle
  2. Hover 1 Eclipse Shell Replacement: adım 2, 3 resimden 1. Hover 1 Eclipse Shell Replacement: adım 2, 3 resimden 2. Hover 1 Eclipse Shell Replacement: adım 2, 3 resimden 3.
    • On the bottom plug side shell pieces, there are two white and pink wires connecting the shell and the motherboard.
    • On the circuit board by the speaker, carefully squeeze and unplug the small white headers that connect the shell piece to the hoverboard body.
    • Follow the wires that connect the lights to the motherboard. Disconnect these wires from the motherboard by squeezing and pulling the small white headers.
    • Now you can fully remove the bottom plug side shell piece.
    FixBot'a Sor
    Yorum Ekle
  3. Hover 1 Eclipse Shell Replacement: adım 3, 1 resimden 1.
    • Unplug the yellow tipped plug attached to the red and black cord on the non-battery side.
    FixBot'a Sor
    Yorum Ekle
  4. Hover 1 Eclipse Shell Replacement: adım 4, 1 resimden 1.
    • Using a Phillips #1 Screwdriver, remove the twelve 11mm and 13mm screws that line the bottom inside of the battery side of the Hover-1 Eclipse.
    • The screw placement is mirrored on the other side
    • Repeat these steps for the left inside of the Hover-1 Eclipse.
    FixBot'a Sor
    Yorum Ekle
  5. Hover 1 Eclipse Shell Replacement: adım 5, 3 resimden 1. Hover 1 Eclipse Shell Replacement: adım 5, 3 resimden 2. Hover 1 Eclipse Shell Replacement: adım 5, 3 resimden 3.
    • Push down the shell and LED light near the center of the board as shown.
    • In the newly exposed area, there will be an 11mm screw holding in the wire that connects to the LED light of the frame. Remove this screw.
    • Now separate the light from the shell and board.
    • Repeat this for the other 3 lights.
    FixBot'a Sor
    Yorum Ekle
  6. Hover 1 Eclipse Shell Replacement: adım 6, 2 resimden 1. Hover 1 Eclipse Shell Replacement: adım 6, 2 resimden 2.
    • Follow the rainbow cord that connects the left side shell piece to the inside board. Find where it is plugged into and disconnect it.
    • The cord is a bundle of multicolored wires sheathed in black, halfway down.
    • Follow the black and blue cord that connects the left side shell piece to the inside board. Find where it is plugged into and disconnect it.
    • Repeat for the top right shell piece.
    • Remove both shell pieces.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Stone Burgan
133 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S12-G4, Regan Fall 2019 Cal Poly, Team S12-G4, Regan Fall 2019 üyesi
CPSU-REGAN-F19S12G4
4 Üyeler
5 adet Kılavuz yazıldı
1Rehber Yorum
Where can I buy the shell please help me
luke - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 33
Her zaman: 1,456
