Ana içeriğe geç
Hover-1 Chrome Battery Replacement
Neye ihtiyacın var
  1. Hover-1 Chrome Battery Replacement, Hover-1 Chrome Disassembly: adım 1, 1 resimden 1.
    • Flip the Hover-1 Chrome upside down.
    • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
    • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
  2. Hover-1 Chrome Battery Replacement: adım 2, 1 resimden 1.
    • Lift the shell without the speaker grille and unplug the battery.
  3. Hover-1 Chrome Battery Replacement: adım 3, 2 resimden 1. Hover-1 Chrome Battery Replacement: adım 3, 2 resimden 2.
    • Lift the shell with the speaker grille.
    • Unplug the speaker.
    • Unplug the LEDs.
    • Unplug the power button
    • Unplug the charging port.
  4. Hover-1 Chrome Battery Replacement, Battery: adım 4, 1 resimden 1.
    • Place the metal spudger end between the blue battery and the adhesive pad that attaches it to the metal body.
    • Use the metal spudger only as a last resort if the adhesive is too strong for either your hands or other plastic prying tools.
    • Use the spudger to pry the battery loose from the adhesive.
  5. Hover-1 Chrome Battery Replacement: adım 5, 2 resimden 1. Hover-1 Chrome Battery Replacement: adım 5, 2 resimden 2.
    • Pull and wiggle the battery completely off of the adhesive using your hands.
    • Remove the battery from the body.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nick McGuire
551 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S4-G1, White Fall 2018 Cal Poly, Team S4-G1, White Fall 2018 üyesi
CPSU-WHITE-F18S4G1
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 27
Her zaman: 1,003
