Ana içeriğe geç
Hover-1 Chrome Bluetooth Speaker Replacement
Neye ihtiyacın var
  1. Hover-1 Chrome Bluetooth Speaker Replacement, Bluetooth Speaker: adım 1, 1 resimden 1.
    • Flip the Hover-1 Chrome upside down.
    • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
    • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
  2. Hover-1 Chrome Bluetooth Speaker Replacement: adım 2, 1 resimden 1.
    • Lift the shell without the speaker grille and unplug the battery.
  3. Hover-1 Chrome Bluetooth Speaker Replacement: adım 3, 1 resimden 1.
    • Lift the shell with the speaker grille so the speaker can be accessed.
    • Remove the three 14 mm Phillips #2 screws holding the speaker to the bottom left shell.
  4. Hover-1 Chrome Bluetooth Speaker Replacement: adım 4, 3 resimden 1. Hover-1 Chrome Bluetooth Speaker Replacement: adım 4, 3 resimden 2. Hover-1 Chrome Bluetooth Speaker Replacement: adım 4, 3 resimden 3.
    • Pull off the bracket holding the speaker in place.
    • Place the speaker to the side so that the tab on the cable connector to the sound card can be accessed.
  5. Hover-1 Chrome Bluetooth Speaker Replacement: adım 5, 2 resimden 1. Hover-1 Chrome Bluetooth Speaker Replacement: adım 5, 2 resimden 2.
    • Disconnect the cable attaching the speaker to the sound card.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Nick McGuire
551 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S4-G1, White Fall 2018 Cal Poly, Team S4-G1, White Fall 2018 üyesi
CPSU-WHITE-F18S4G1
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 720
