Ana içeriğe geç
Hover-1 Chrome LED Headlights Replacement
Neye ihtiyacın var
  1. Hover-1 Chrome LED Headlights Replacement, Hover-1 Chrome Disassembly: adım 1, 1 resimden 1.
    • Flip the Hover-1 Chrome upside down.
    • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
    • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
  2. Hover-1 Chrome LED Headlights Replacement: adım 2, 1 resimden 1.
    • Lift the shell without the speaker grille and unplug the battery.
  3. Hover-1 Chrome LED Headlights Replacement: adım 3, 2 resimden 1. Hover-1 Chrome LED Headlights Replacement: adım 3, 2 resimden 2.
    • Lift the shell with the speaker grille.
    • Unplug the speaker.
    • Unplug the LEDs.
    • Unplug the power button
    • Unplug the charging port.
  4. Hover-1 Chrome LED Headlights Replacement, LED Headlights: adım 4, 3 resimden 1. Hover-1 Chrome LED Headlights Replacement, LED Headlights: adım 4, 3 resimden 2. Hover-1 Chrome LED Headlights Replacement, LED Headlights: adım 4, 3 resimden 3.
    • Use a Phillips #2 screwdriver to remove the two 2 mm screws on either side of the LEDs.
    • Remove the LED board.
    • The LEDs are not symmetrical. This step is for the right side of the board, next to the power button. The left side is covered next.
  5. Hover-1 Chrome LED Headlights Replacement: adım 5, 2 resimden 1. Hover-1 Chrome LED Headlights Replacement: adım 5, 2 resimden 2.
    • Locate the LED headlights on the left side of the board.
    • Pull the red wire attached to the LEDs perpendicular to the other wires to disconnect it.
  6. Hover-1 Chrome LED Headlights Replacement: adım 6, 3 resimden 1. Hover-1 Chrome LED Headlights Replacement: adım 6, 3 resimden 2. Hover-1 Chrome LED Headlights Replacement: adım 6, 3 resimden 3.
Sonuç
Nick McGuire
551 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S4-G1, White Fall 2018 Cal Poly, Team S4-G1, White Fall 2018 üyesi
CPSU-WHITE-F18S4G1
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 348
