Ana içeriğe geç
Hover-1 Chrome Outer Shell Replacement
Neye ihtiyacın var
  1. Hover-1 Chrome Outer Shell Replacement, Hover-1 Chrome Disassembly: adım 1, 1 resimden 1.
    • Flip the Hover-1 Chrome upside down.
    • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
    • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
  2. Hover-1 Chrome Outer Shell Replacement: adım 2, 1 resimden 1.
    • Lift the shell without the speaker grille and unplug the battery.
  3. Hover-1 Chrome Outer Shell Replacement: adım 3, 2 resimden 1. Hover-1 Chrome Outer Shell Replacement: adım 3, 2 resimden 2.
    • Lift the shell with the speaker grille.
    • Unplug the speaker.
    • Unplug the LEDs.
    • Unplug the power button
    • Unplug the charging port.
  4. Hover-1 Chrome Outer Shell Replacement, Outer Shell: adım 4, 1 resimden 1.
    • Remove the twelve 14 mm Phillips #2 screws holding the top shell on.
    • The other six screws are on the side without the battery.
  5. Hover-1 Chrome Outer Shell Replacement: adım 5, 3 resimden 1. Hover-1 Chrome Outer Shell Replacement: adım 5, 3 resimden 2. Hover-1 Chrome Outer Shell Replacement: adım 5, 3 resimden 3.
    • Free the cables held atop the bracket holding the battery in place.
    • Remove the four 14 mm Phillips #2 screws holding the battery bracket in place.
    • Pull the battery bracket free.
  6. Hover-1 Chrome Outer Shell Replacement: adım 6, 1 resimden 1.
    • Unplug the cords for the top LEDs.
    • The other side of the board is structurally symmetrical. However instead of going under the battery bracket, these cords go through a zip tie. These cables must be removed from the zip tie in order to continue.
  7. Hover-1 Chrome Outer Shell Replacement: adım 7, 1 resimden 1.
    • Turn the board over and pull the top panel off.
Bitiş Çizgisi
Dylan Prins
212 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S4-G1, White Fall 2018 Cal Poly, Team S4-G1, White Fall 2018 üyesi
CPSU-WHITE-F18S4G1
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Where can i get a replacement shell?
born4roblox - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 12
Her zaman: 326
