Ana içeriğe geç
Hover-1 Coast Board Battery Replacement
Neye ihtiyacın var
    1. Hover-1 Coast Board Battery Replacement, Board Battery: adım 1, 3 resimden 1. Hover-1 Coast Board Battery Replacement, Board Battery: adım 1, 3 resimden 2. Hover-1 Coast Board Battery Replacement, Board Battery: adım 1, 3 resimden 3.
      • To remove the battery on the Hover-1 Coast, you must uncover the screws on the top of the board.
      • Using a pick tool, puncture the grip tape and expose the screws.
      • Loosen all four 1" screws using a Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Hover-1 Coast Board Battery Replacement: adım 2, 3 resimden 1. Hover-1 Coast Board Battery Replacement: adım 2, 3 resimden 2. Hover-1 Coast Board Battery Replacement: adım 2, 3 resimden 3.
      • Now pull the black protective cover off the board.
      • Locate the battery.
      FixBot'a Sor
      Yorum Ekle
    3. Hover-1 Coast Board Battery Replacement: adım 3, 3 resimden 1. Hover-1 Coast Board Battery Replacement: adım 3, 3 resimden 2. Hover-1 Coast Board Battery Replacement: adım 3, 3 resimden 3.
      • The battery is connected by these two sets of wires.
      • Remove the yellow wire first by pulling the two wires gently in opposite directions.
      • Now pull apart the black wire by gently pulling the two wires in opposite directions.
      FixBot'a Sor
      Yorum Ekle
    4. Hover-1 Coast Board Battery Replacement: adım 4, 3 resimden 1. Hover-1 Coast Board Battery Replacement: adım 4, 3 resimden 2. Hover-1 Coast Board Battery Replacement: adım 4, 3 resimden 3.
      • Once the battery has been disconnected, gently pry the battery upward.
      • It is important to use a plastic opening tool to avoid puncturing the battery.
      • Once the battery is freed, remove it with your hands.
      • The battery is glued to the case and will require some effort to remove.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Where can you order a replacement battery?
Phil - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 32
Her zaman: 1,050
