Giriş
In order for your Hover-1 Coast to be used for its intended purpose you must have a functioning battery. This procedure is fairly easy to accomplish and key to using the board to its full potential.
Neye ihtiyacın var
To remove the battery on the Hover-1 Coast, you must uncover the screws on the top of the board.
Using a pick tool, puncture the grip tape and expose the screws.
Loosen all four 1" screws using a Phillips #1 screwdriver.
Bir başkası bu kılavuzu tamamladı.
