Ana içeriğe geç
Hover-1 Coast Trucks Replacement
Neye ihtiyacın var
  1. Hover-1 Coast Trucks Replacement, Trucks: adım 1, 3 resimden 1. Hover-1 Coast Trucks Replacement, Trucks: adım 1, 3 resimden 2. Hover-1 Coast Trucks Replacement, Trucks: adım 1, 3 resimden 3.
    • In order to remove the trucks on the Hover-1 Coast, you must uncover the screws on the top of the board.
    • Using the pick tool to puncture the grip tape and reveal the screws.
    • The board should look like this.
  2. Hover-1 Coast Trucks Replacement: adım 2, 3 resimden 1. Hover-1 Coast Trucks Replacement: adım 2, 3 resimden 2. Hover-1 Coast Trucks Replacement: adım 2, 3 resimden 3.
    • Once all four screws have been revealed, locate the socket wrench and the Phillips #1 screwdriver in the wrench handle.
    • Place the 9/16 inch socket wrench over the nut; place the the Phillips #1 screwdriver in the screw.
    • Hold the socket wrench in place and twist the screwdriver counterclockwise to loosen the nuts.
  3. Hover-1 Coast Trucks Replacement: adım 3, 3 resimden 1. Hover-1 Coast Trucks Replacement: adım 3, 3 resimden 2. Hover-1 Coast Trucks Replacement: adım 3, 3 resimden 3.
    • Remove the nuts from the bottom of the board.
    • Slide the unwanted trucks off the screws.
    • The black rubber spacer will stay on the board.
Sonuç
Alaina Limon
97 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 266
