Ana içeriğe geç
Hover-1 Coast Wheel Replacement
Neye ihtiyacın var
  1. Hover-1 Coast Wheel Replacement, Wheel: adım 1, 1 resimden 1.
    • Identify the wheel you are wanting to replace.
  2. Hover-1 Coast Wheel Replacement: adım 2, 2 resimden 1. Hover-1 Coast Wheel Replacement: adım 2, 2 resimden 2.
    • Find the Socket wrench located in the Hover-1 Coast packaging.
    • Use the 9/16 inch side to loosen the skateboard nut by turning counterclockwise.
  3. Hover-1 Coast Wheel Replacement: adım 3, 3 resimden 1. Hover-1 Coast Wheel Replacement: adım 3, 3 resimden 2. Hover-1 Coast Wheel Replacement: adım 3, 3 resimden 3.
    • Remove the nut off the axle.
    • Remove the washer off the axle.
  4. Hover-1 Coast Wheel Replacement: adım 4, 3 resimden 1. Hover-1 Coast Wheel Replacement: adım 4, 3 resimden 2. Hover-1 Coast Wheel Replacement: adım 4, 3 resimden 3.
    • To avoid losing any parts, place them on a flat surface.
    • Slide the unwanted wheel off the axle.
    • Slide the new wheel on the axle.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 431
